20 Most Recent Motorola Mobility H700 Wireless Headset Questions & Answers
Replace battery h700
Well you can please follow the below step -
1. Make sure you actually need battery replacements. Wrong use of the unit can lead to faulty functioning. If you have recently bought the device, charge the unit for approximately 2 hours and let the unit drain its energy completely before recharging to give the maximum battery life span.
2. Turn off the unit before attempting a battery replacement. Without doing so, the power disruption that the headset will acquire can damage the internal workings.
3. Find the even **** on the bottom side of the unit, where the microphone boom is attached.
4. Place the edge of the flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
5. Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out. Please post comments for more help or information.........
Good Luck!!
4/18/2024 8:06:50 PM • Motorola... • Answered on Apr 18, 2024
2answers
Broke the ear hook for the Motorola h500 bluetooth headset
I searched on google for motorola h700 and found plenty of sources? Amazon.com and others.
12/8/2022 11:54:59 AM • Motorola... • Answered on Dec 08, 2022
People cannot hear me
It can happen when phones update their software. It also can occur when the earset battery gets too old to hold the full charge.
12/12/2017 8:34:41 AM • Motorola... • Answered on Dec 12, 2017
0answers
Bluetooth
Be the first to answer 5/3/2017 9:48:03 PM • Motorola... • Posted on May 03, 2017Be the first to answer
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
5/3/2017 4:52:50 PM • Motorola... • Answered on May 03, 2017
2answers
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    11/26/2016 3:24:33 AM • Motorola... • Answered on Nov 26, 2016
    How to change my battery on h700
    Hi Aggie, So sorry to hear that, let me tell you that we don't longer manufacture those devices but if you are able to find a battery in a third party site like Amazon or best buy. Hope you can solve the issue. Regards, Marvin Motorola Support.
    10/6/2016 7:29:17 PM • Motorola... • Answered on Oct 06, 2016
    3answers
    I cant hear anything out of my headset
    Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
    1/28/2016 2:01:56 PM • Motorola... • Answered on Jan 28, 2016
    Am trying to put 0000 as the passkey but the bluetooth device did not accept.what can i do?
    try another pass key as the system may not accept that combination
    11/8/2015 10:31:30 PM • Motorola... • Answered on Nov 08, 2015
    H700: Need pairing code for sanyo
    Kingram and Mike- On nearly all our headsets it is 0000. Mark Motorola Support
    4/24/2015 12:00:14 PM • Motorola... • Answered on Apr 24, 2015
    When I plug it in its green when I unplug it the thing will not do anything
    Chris Charge with boom closed. If previously paired with your phone and bluetooth is enabled. It should auto connect when boom is opened. Pairing on this model is tricky for some. Mark Motorola Support
    3/5/2015 10:35:39 PM • Motorola... • Answered on Mar 05, 2015
    Motorola wireless H700 is not functioning. I can not turn it on after charging as I used to, Why?
    Is the mic boom open? That is the power switch. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf Mark Motorola Support
    3/4/2015 12:35:18 PM • Motorola... • Answered on Mar 04, 2015
    Moto H700: How do I install new batteries in syn1311B headset?
    The batteries in our headsets are not intended to be swapped. Mark Motorola Support
    2/23/2015 4:12:22 AM • Motorola... • Answered on Feb 23, 2015
    How do I pair motorola h700 with motorola defy?
    Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy. Mark Motorola Support
    2/10/2015 12:23:38 PM • Motorola... • Answered on Feb 10, 2015
    My h700 won't turn on
    Mark- I remember this headset being difficult for people to get in pairing mode. You can find instructions here. H700 Different Paring Instructions Mark Motorola Support
    1/13/2015 3:23:04 AM • Motorola... • Answered on Jan 13, 2015
    Add mute switch
    Have you tried both volume buttons simultaneously while in call? Otherwise your phone probably has a one button option. Mark Motorola Support
    1/12/2015 1:15:43 PM • Motorola... • Answered on Jan 12, 2015
    Motorola Mobility H700 Wireless Headset Logo
    756 questions posted
    Top Motorola Mobility Radio Communications Experts
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Motorola Mobility Radio Communications
    Most Popular Question
    h700 bluetooth hear caller but 39 t
    • Radio Communications
