20 Most Recent Plantronics Explorer 240 Bluetooth Headset Questions & Answers
The problem is that when
Try deleting the headset from your phone and then repairing the two again.Good luck from Headsets Direct!
1/12/2017 8:24:05 AM • Plantronics... • Answered on Jan 12, 2017
I bought a ZK-S8 buetooth headset how do I listen to music on it
Need to put the headset into pairing mode (see instructions) then link it to whatever device you're planning on using for a source of music. If it's your cell phone (which I'm assuming is the source) go into the bluetooth menu and link it up to the headset. May need a password for it that too you will get from the instructions. Once you do all that you should be able to play music on the headphones. Any more problems after that and you should check the output source selection on the music source.
6/19/2014 4:16:52 AM • Plantronics... • Answered on Jun 19, 2014
Have a samsung rugby phone my plantronics explorer 240has paired but wont connect
turn your phone off and back on
4/29/2013 8:36:36 AM • Plantronics... • Answered on Apr 29, 2013
I have a samsung gusto sch-u365 and i want to pair it with the plantronics 240
In case you have never paired your headset to another phone before, just by turning it on, it should enter the pairing mode, denoted by its indicator light flashing alternately in red and blue. Otherwise, i.e. if it was paired to another phone before, press and hold the call control button until its indicator light flashes alternately in red and blue. Then, on your phone, press the left softkey and go to 'Menu > Settings > Bluetooth > Add New Device'. After a little while, your headset should appear on-screen. Using the directional key, select your headset and press 'Pair'. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the standby mode (blue light flashing every few seconds). There might be an indication on your phone screen that a bluetooth device is connected as well.Hope it works for you.By the way, in case any (or both) your headset and/or phone user guides happen to be missing, feel free to download them from here (headset) and/or here (phone).Anyway, please, let me know if you need further informations.Best regards,Carlos
6/10/2012 6:14:24 PM • Plantronics... • Answered on Jun 10, 2012
My bluetooth is paired i can not hear out of it
t sounds like the phone and headset may not be paired up correctly. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on. Purge from the phone any pairing information for your Explorer 240 headset and pair it again to your phone, following carefully the instructions on the attached link for the Plantronics Explorer 240. Also, make sure there isn't any other bluetooth interference.Plantronics Explorer 240 User's GuideGood luck from Headsets Direct!
2/29/2012 10:18:26 PM • Plantronics... • Answered on Feb 29, 2012
Make noise
I'm sorry but intermittent noise is like telling your mechanic you hear a rattle somewhere in your car. Like that poor mechanic, I'm going to take a stab at your problem. Check pages 6-8 in the user guide below and see which "noise" best fits your situation. You can generally fix it by powering down your headset and then powering back up (instructions are in the same guide).Plantronics Explorer 240 User's GuideGood luck from Headsets Direct!
2/29/2012 9:46:21 PM • Plantronics... • Answered on Feb 29, 2012
Can you please help me, I have an Plantornics
Try letting the battery go dead on the headset, then recharge it back up and see if that fixes your problem.Good luck from Headsets Direct!
12/27/2011 8:32:14 PM • Plantronics... • Answered on Dec 27, 2011
Plantronics Explorer 240 Bluetooth Headset Logo
Popular Tags
73 questions posted
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Plantronics Radio Communications
Most Popular Question
connect
  • Radio Communications
