Hello , glad to help you. (has = have)?
what are you attempting, ? my guess,
I guess you are asking for us to read your product spec.
and to see if it supports
NVMe 2 SSd Card
aka m.2 DDS.
I thinks the answer is no. I read 2 product specs
and is not listed
why not ask at Lenovo, they have books we cant find.
they made it so.... they know.
only they know all questions.
I say NO
but do ask them. here at the makers site< ok?
https://forums.lenovo.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&filter=location&location=category%3ACommunity-EN&q=G70+
or read the makers of Nvme pages , for the support list
I see none on G70 there.
if using a Samsung NVME, like me now, read there pages
on what they support, and G70 is not it.
I think ALL Gnn are not supported, one post said G40 , is not.
no books show it.
SOURCE: How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/default...B;en-us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
SOURCE: Is AGP slot acepting PCI express card?
Yes, your motherboard actually does contain an AGP 8x VGA interface. (ASUS reference is at http://www.asus.com/products.aspx?l1=3&l2=12&l3=31&model=179&modelmenu=1 AND http://www.asus.com/products.aspx?l1=3&l2=12&l3=31&model=179&modelmenu=2.) This means that the video card you replace the All in Wonder with must meet that specification unless you are prepared to switch out the board.
However, as the card you have indicated above is a PCIE x16 card, that may represent additional compatibility options. (The reference for this card is here: http://ati.amd.com/products/radeonx1300/aiw2006pcie/specs.html). This is a bit confusing, given that the motherboard specs indicate an AGP 8x interface. There is the indication on the "modelmenu=2" page that the MB includes 5 PCI expansion slots, but there is no mention of any PCIE x16 interface.
It is often best to return to the site of the manufacturer, or a respected seller, to check for compatibility with the specific brand and model of your PC. This would likely be the best approach, and if you would like for me to help with that, please post back with the information.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
SOURCE: faulty motherboard?
bullnosestep
It is possible that the new (secondhand graphics card) was faulty and sent an incorrect voltage to part of your motherboard (frying it). However in my experiance it is not likely, I have installed and un-installed 100's of video cards over the last 10 years many of them faulty and only on one ocassion did it ever damage the board.
Things to try:
Double check (triple check) that your card is seated properly in the pci-e slot, this is one of the most overlooked things and is one of the most common problems when installing a new video cards. It may be drawing power from the slot but could still be slightly out of line.
Also most new ish psi-e card require an additional power supply direct from the PSU, did you connect this up if needed. (don't know what make the graphics card is so just in case)
Remove the cards and check the slot for dust and dirt, quite often when you remove an old existing card you can dislodge dust/durt from around the slot pushing it into it, thus making a bad connection to the video card. Blow the slot clean with a compressed air cleaner, can should cost £5-£10, don't use vacuum on the motherboard as this can cause extreme levels of static.
Are you sure you didn't knock a component on the motherboard during installation?
If you have tried all these things then you may have a damaged board. You could take it to a repair outlet to check the board over. They would be able to check the voltages etc... and may be able to locate the trouble.
The Pci-e slots can be replaced and re-soldered but it is a very skilled operation, to be fair you would be much better off buying another board. Lets face it, the slot is probably ok, you may have blown something elsewhere on the board.
Hope this helps and let me know if you solve the problem
Bri
SOURCE: How to use the sim card slot of Lenovo s10-3t
Hi. Maker sure upon ordering the computer at lenovo you requested for a 3G capability. The slot might be there but it is actually disabled. Enabling the 3G slot will need your laptop to be sent out at our repair department. If the 3G slot is enabled, all settings should come from you Insternet service provider.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
