20 Most Recent EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Questions & Answers
Check with the motherboard manufacturer for the significance of the error code you have received and then act accordingly.
EliteGroup ECS... | Answered on May 24, 2016
Boot your pc from a windows-cd.
Without reprogramming, find the repairbutton.
Try to REPAIR.
Reboot normal.
EliteGroup ECS... | Answered on Jan 01, 2016
A manual for the Motherboard 945GCT-M/1333 (V3.0) can be found at the link below. Gateway's support site does not recognize 945GCT-NM as a valid Gateway model number.
http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/945GCT-M1333_v3.0/22_945GCT-M%201333%20(3.0)_Low.pdf
EliteGroup ECS... | Answered on Sep 08, 2015
I have a link to realtek audio drivers http://www.dslreports.com/forum/r23068431-Free-Realtek-Drivers-for-most-Realtek-10-100-1000-network-card
EliteGroup ECS... | Answered on May 28, 2015
Go to this link and download the motherboard manual. It will show what header pins on the board attach to your various panel connections.
ECS Web Site 945GCT M3 V3 0
EliteGroup ECS... | Answered on Aug 21, 2014
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&MenuID=1&LanID=0
EliteGroup ECS... | Answered on Aug 19, 2014
go here ok jim http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&MenuID=1&LanID=0
Connect your power switch to the F-Panel connector, pins 6 and 8
EliteGroup ECS... | Answered on Aug 18, 2014
download from here under download http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=727&MenuID=16&LanID=0
EliteGroup ECS... | Answered on May 25, 2014
I see what you mean, ECS say's it's a Realtek device. Then Realtek driver site keeps looping the XP links. In any case, I finaly found a good link. Here is the zip link.
ftp://WebUser:r3iZ6vJI@202.134.71.21/cn/nic/Driver_XP_5800_09202012.zip
They are newer than those posted on ECS, and if this does not work you should consider buying a new PCI NIC.
Good Luck
EliteGroup ECS... | Answered on May 16, 2014
Try another memory brand! Maybe memory you have in there not compatible. Have you tried testing your video card make sure it's not a bad video card?
look for the jp1 connector, pins 6-8 are usually power on/off and 2-4 are usually for reset
EliteGroup ECS... | Answered on Mar 21, 2014
Hello Nelson, most likely you may need a new motherboard. But here are some thing you may try before considering on buying one,
  1. try replacing a new motherboard battery.
  2. reset you bios. locate jumper cmos battery.
let me know your progress.
EliteGroup ECS... | Answered on Jan 03, 2014
Hello Andreas, clean memory slot and DDR2 module.
EliteGroup ECS... | Answered on Dec 05, 2013
Hello Pedro, Hi, the hissing sound comes from the power supply box. try another one, make sure connection are tight and secure.
Hello Abhramukherj, try cleaning the memory slot. reset CMOS and retest RAM sure 100%.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
EliteGroup ECS... | Answered on May 26, 2013
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
179 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
cannot find startup file
  • Computers & Internet
