Bent a needle and had a horrible time getting it off machine but did and put on another needle - now machine knots the bottom thread every 4 or 5 inches?
Owner's manual, No manual?
try http://www.manualsonline.com/
SOURCE: The safety device has been activated.
It is under warantee for 12 months, so I would recommend you phone the dealer to arrange for them to have a look at it.....if you have any samples of sewing, take them too.
SOURCE: singer 6412- thread loops up and knots up on bottom of material
"Birdnesting" occurs when there is no tension on the needle thread to
pull the bobbin thread. This is easily corrected by rethreading the
machine, following the threading path carefully and making sure the
thread is fully engaged in the tension mechanism.
Good luck ..
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
