I sew alot. I sew all mine and my 2 daughters clothes. i just finished a dress with no issues at all. when i started another dress, there was problems right away.
SOURCE: loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
SOURCE: Right needle skipping stitches Janome 4623LE
if you adjust that setting, check that the needle goes into the needle plate the exact same distance front to back on both the right and left side. Also, be careful not to change the height when changing the twist.
SOURCE: BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Testimonial: "Thanks, this was very helpful!"
