Hello Cindy!
I would like to suggest that you download the Free IOBit Uninstall Program from CNET.com, or from any other WEBSite. I have been using this free program and it will help you to uninstall the program, any Program, as well as its, their, Registry entries with a single click of your Mouse after you downloaded, installed the program, and you rebooted your Device. I know this will help! Find this program, download it, install it with
a shortcut on your Desktop and reboot your PC! Than Right Click on it and run it to run it as an Administrator. Than click the Program you want to uninstall, and click remove or uninstall it,
This Program will clean your PC and remove the program as well its Registry Entries as well! Lastly, this program will also Uninstall any junk files that came with the Program! Steve Horvath, Chicago, IL
1)Uninstalling any unwanted or unused software in your Lenovo laptops can be done easily by following these simple steps.
2)Firstly, backup all the necessary documents and other information related to the application before uninstalling it. If the software has its own uninstaller, run it directly in order to uninstall the program.
3)If the software does not have the uninstaller, then you will have to navigate to the Programs and Features option from the Control Panel of your system.
4)Locate the application that you wish to uninstall from the programs and features dialog box. Right-click on the application and then choose the option Uninstall from the drop-down list.
5)Perform the instructions displayed onscreen to complete the uninstalling process.
For more printer related assistance just give a call @ 1-866-293-9220.
Hi Cindy
well that varies by the OS.
called a G series laptop at makers site
my wild guess, per makers site
the PC came with windows 7, and not Linux. or newer. windows
click start
so click control panel
click programs
just 3 clicks.
this works on all versions of windows if running windows.
SOURCE: i can not install network
Check any viruses are present in the OS, scan and remove it, restart and then try reloading it.
SOURCE: my laptop lenovo /G555 has
what kind of problem you are encountering with webcam?
try to press Fn+esc to open the webcam if not work you may wanna try to go to consumersupport.lenovo.com to get the latest camera driver and make sure it is compatible to your Operating System by checking the OS on the right side of the camera driver(lenovo.com)
SOURCE: unlocking forgotten password lenovo g555
Welcome to Fixya
If you are referring to the BIOS password then there is no other way to unlock that. You need to send in you computer to lenovo Depot repair department. The number is 18774536686.
Thank you for choosing Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Lenovo G555 overheat
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
