Home Logo
Ruth Wells Posted on Oct 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to find a user manual for a maax hydromax whirlpool tub that is was purchased approx 2002 the jets have stopped working
If voltage past switch and relay bad pump motor
Kevin.
Level 2:
Sergeant:
  • Expert 256 Answers
  • Posted on Dec 07, 2018
Kevin.
Expert
Level 2:
Sergeant:
Answers
256
Questions
0
Helped
75472
Points
517
3 Related Answers
Anonymous
  • 123 Answers
  • Posted on Sep 08, 2009
SOURCE: Hi, We purchased a Maax 10 jet Whirlpool tub
http://www.maax.com/Upload/guides/fr/000_10050073_0305.pdf.......this should take care of what you need. If you have any questions just ask.
Thx
Ken
Anonymous
  • 10 Answers
  • Posted on Oct 08, 2009
SOURCE: I don't know how to work my Maax hydromax double
Try to downlaod the manual from the maax website. Hopefully you can find the model #. Look around in the pump acess area for it. If you cant find it try to match it up with a current model image from the website or do an online image search. All major companies offer there liteture available online somewhere, maybe under a seperate tab, on the product page.
If this does't help you should post again and be more specific i.e. what can't you get to work? Tubs these days have many different feaatures. Also model # and estimate what year it may be.
Wish I could have been of more help.
Sincerely, T. Wood C&F Enterprises a plumbing contractor.
Anonymous
  • 731 Answers
  • Posted on Feb 05, 2011
SOURCE: We purchased a home with the Maax Hydromax
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=27963&ven=3726866
This is the only site i could find they might be able to get the info for you
Can't turn on Whirlpool
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 09, 2014 • Maax Home
2answers
We don't know how to operate our maax hydromax system. We moved into our house and the tub has never worked. We get a message no h2o and then sometimes it will do a countdown from 10. Is there a
This sounds as if the low water sensor may not be working. They are designed to know when the tub has water in it and then the motor will start.
What is the model number of the control box under the tub that the pump plugs into?
If we can figure out the control then we can find a solution for you.
Rod
www.uspartscenter.com
Jan 27, 2013 • Maax Home
Where is the filter located on a maax whirlpool drop-in tub
As far as I know you do know have a filter. I have read my instruction manual and it does not mention a filter at all. I have the Topaz 6036. To clean it you are to fill your tub with water and put in dishwasher detergent and let the tub run for a few minutes. You can also add a small amount of bleach.
1helpful
I need a manual
Call Maax or visit their website and you can download the manual for it.
2helpful
2answers
Maax infinity hot tub error code clfl dont have the manual
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Thx
Ken
Aug 12, 2009 • Home
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
