20 Most Recent Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2 Questions & Answers
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=27963&ven=3726866
This is the only site i could find they might be able to get the info for you
Maax Studio... | Answered on Feb 05, 2011
Finally resolved this on our own tub. We had C01 and E06 error alternating. After gaining access to the service door for the tub, I was able to determine that the ribbon cable for the water detector going to the electronics box on the back of the pump had become loose. After plugging it back in and then powering off/on the pump, the blinking light on the back of the pump went back to solid and the error on the control panel eliminated.
Maax Studio... | Answered on Oct 11, 2010
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Maax Studio... | Answered on Jul 13, 2009
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Maax Studio... | Answered on Dec 12, 2008
Request the manual from Maax.
Maax Plumbing | Answered on May 15, 2018
and what is your question --if you want to complain notify the company
Maax Plumbing | Answered on Apr 30, 2018
There are 2 types of litghly cover. A twist off (1/4) turn and a some pry off. It shouldn't be required hi torque. Try twist off first counter clockwise
Maax Plumbing | Answered on Jun 02, 2017
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Maax Plumbing | Answered on Mar 24, 2017
Maax Studio 1-Piece Hydromax Whirlpool Tub Shower with Drain & MAAX IES 1/2 Logo
Popular Tags
18 questions posted
Top Maax Plumbing Experts
Donni Steen
john h
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Maax Plumbing
  • Maax Plumbing
Most Popular Question
e06 error get rid flashing
  • Plumbing
