SOURCE: BMW remote control problem
I have a e60 525i that I just brought and it has the same problem, the owners manual suggests driving with the key in the ignition for a long time as the batteries are rechargable and may have gone flat, i have tried this and it doesnt seem to work
i also read something about getting water in the aerial about the rear window and that wrecks the receiever. My car isn;t under warranty so not looking forwarding to taking it to bmw
SOURCE: Sensor lights not working on door opener
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
SOURCE: My LG Tromm detergent door is stuck closed and I
Here's what I would do:
Take the two screws off the back plastic parts which are attached to the top cover. Leave the ones in that go into the cover, just remove the bottom one on each side.
Now, standing in front of the machine, use the palms of your hands to sharply push back the top cover (pushing on the right and left edge of the top). It only moves about two inches. Now, lift the cover off.
Use a flashing to try to see into the semi opaque dispenser to determine where the hang up is.
Drill a small hole in the top of the dispenser chamber to allow you to poke an object like a screw driver in to manuver the offending part of the dispenser, allowing removal of the dispenser drawer. Use a peice of foil duct tape to seal the hole you previously drilled.
SOURCE: cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
SOURCE: samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Testimonial: "thanks, ill try that now"
