20 Most Recent GE Monogram ZDI15C Automatic Icemaker Questions & Answers
 Whenever the unit has reached a failure mode, the LED will flash, and the unit will shut down. If the failure was caused during a harvest cycle which lasted more than 16 minutes, the LED will remain flashing on & off in halfsecond increments. If the failure is caused by a faulty bin thermistor, (not detected), the LED will remain flashing on & off in 1-second increments. These are the only two failures that cause the unit to reach a shutdown failure mode. x During the Clean cycle, the control board performs the diagnostics first. If the bin thermistor is not detected, the LED will flash two times. This is followed by a 3-second delay. If the evaporator thermistor is not detected, the LED will flash on five times. This will be followed by a 3-second delay. The LED will then come back on, and remain on for the remainder of the Clean cycle, and until the unit is turned back on.
GE Monogram... | Answered on May 21, 2019
my best guess is the board in the door.try appliance parts pros.they have the best warrenty on parts.
GE Monogram... | Answered on Nov 23, 2017
These units often have a hard-to-see reset button to resume proper operation. Look hard or check your manual.
GE Monogram... | Answered on Apr 14, 2017
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
GE Monogram... | Answered on Aug 23, 2015
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
GE Monogram... | Answered on Jun 24, 2015
Check freezer temp since no ice will be produced if temp does not hit around 10 degrees or less.
GE Monogram... | Answered on May 11, 2015
Don't use clr... use recommend descaler
GE Monogram... | Answered on Jan 15, 2015
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
GE Monogram... | Answered on Nov 17, 2014
Replace the bin thermostat
GE Monogram... | Answered on Nov 06, 2014
Is the cutting grid getting warm if just warm make sure you don't have any loose wires supplying power to grid. Check grid cutting transformer to make sure it is working. make sure grid is clean. If you are getting power to cutting grid and it's not getting warm then cube let cutter grid is bad. If this needs to be replaced you might thank about a new machine the cost for this part is around 480.00 part number AP2068335
BIN Thermistor part number 2313633 from sears.
It's best to have a qualified service company properlly diagnose your appliance failure. Something to check would be removing the to kick grill, and making the sure the condenser coil is clean and free of dust. It's rare that you would have a freon issue, but may be experiencing a sealed system issue such as an internal leaking reversing valve allowing the freon to be channeled in two directions within the system instead of just one. Pleazer Appliance...
GE Monogram... | Answered on Aug 25, 2014
Have you checked to see if you have power to the unit. give me some more info.
GE Monogram... | Answered on Jul 30, 2014
It is still taking on water when hopper is full , like the arm that shut off the water is stuck open?? what is happening?
GE Monogram... | Answered on Jul 26, 2014
it may be not getting the right amount of water check the float or soliniod valve if it is equipped.
GE Monogram ZDI15C Automatic Icemaker Logo
Popular Tags
254 questions posted
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
geapptech
Audie Bogus
Audie Bogus
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • GE Kitchen Appliances - Others
Most Popular Question
ice machine not making ice
  • Kitchen Appliances - Others
