Washing Machines Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noisy bearing - Washing Machines
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
0
Helped
34897
Points
227
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpnoisy bearing - mag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Add Your Answer
    What can cause noisy spin on wd960 hotpoint ?
    bad bearings, seal leak let water in bearings
    Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
    How to change noisy bearing on Ariston AQXXF 129
    inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
    Hotpoint condenser dryer noisy
    hi if you push inside top at back of drum u will feel if lift if so yes u need bearing just ask for rear bearing for your model more than likely teardrop bearing
    Lg intellowasher wd-8013f is very noisy
    it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
    1helpful
    Aquarius 1100 wm63 very noisy spinning
    Remove rear cover of washer.
    Remove drive belt.
    From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
    If no noise, then possibly motor bearings noisy.
    Hope this helps Thankyou.
    Noisy noisy noisy!
    Without being there, it is hard to say. You need to consider tire condition - large mud tires are noisy; tires over inflated will be noisy; a bad driveline u-joint will make noise; drive line bearings, wheel bearings all could be a factor. have a mechanic friend ride with you and help pinpoint the cause.
    2helpful
    Washing machine really noisy on spin!
    Probably main drum bearings worn
    If you turn the drum by hand and it feels rough or noisy ,then definately bearings worn and noisy.
    1helpful
    Bearings very noisy on the drum
    aquarius w f 541 1400 spin drum bearing noisy
    1helpful
    Wm noisy
    drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
    Top Washing Machines Experts
    john h
