SOURCE: Need Bosch stand mixer's model number to buy replacement parts
Just some added information. The number you have may be a part number. I ahve the exact same number on my Bosch Universal Mixer. What i'm looking for is a new casing, mine is broken.
SOURCE: nextar X-11-15302 or P3
A generic 12 volt adapter should work. I replaced mine recently. They usually come with multiple sizes of round ends and can adjust the output voltage. The side of the device will tell you the polarity and the voltage required. If it says something like 5 V but the adapter only has 4.5 V or 6 V, select the closer choice. If they're about equal, select the lower one. It is better to have an under volt than an over volt.
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
SOURCE: Panasonic ER389 Trimmer Battery Pack
I read "alfadogs" suggestion and found that Sanyo KR-11--AAUT is obsolete. Found that Digi-key's part # P015T-ND works great. It is a NIMH that is a a little bit larger - but fits just fine. The charge rate of the ER389 works well and does not heat this battery. John
SOURCE: I HAVE BOUGHT PANASONIC ER224RC TRIMMER I HAVE
Panasonic ER224RC. Plastic head/comb attachment broken. How do I get a new one?
