SOURCE: Hi,I am getting a Casio CTK-810 in the next couple
No. There is however a function to store 4 "registration" settings for easy recall, in case you want to change sounds in the middle of a song. Those settings are erased when the keyboard is turned off.
Hope this helps!
SOURCE: Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
SOURCE: Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
SOURCE: Casio Ctk 496 Electronic Keyboard with 61 Keys, drivers needed
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
