20 Most Recent Casio Privia Px330 Px-330 88 Key Digital Piano New Questions & Answers
Where is there a service manual for a casio privia px330
https://shema.info/en/service-manuals/3311-servis-manual-3311.html
1/2/2019 4:45:12 PM • Casio Privia... • Answered on Jan 02, 2019
How do i adjust the drum rhythm volume so it is louder than the tone settings
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127. Please read the manual. Metronome volume can be easily changed by just holding the metronome button.
8/12/2014 11:33:41 AM • Casio Privia... • Answered on Aug 12, 2014
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers. Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
8/12/2014 10:52:52 AM • Casio Privia... • Answered on Aug 12, 2014
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD. Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
8/11/2014 12:03:29 PM • Casio Privia... • Answered on Aug 11, 2014
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used. However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
5/18/2014 10:13:30 AM • Casio Privia... • Answered on May 18, 2014
Pitch drifts px 330
If anyone using a wireless guitar setup is close to it when playing, can do that.
2/28/2014 12:57:11 AM • Casio Privia... • Answered on Feb 28, 2014
0answers
Key stuck
Be the first to answer 2/22/2014 5:46:39 PM • Casio Privia... • Posted on Feb 22, 2014Be the first to answer
0answers
Error loading
Be the first to answer 1/30/2014 6:00:09 AM • Casio Privia... • Posted on Jan 30, 2014Be the first to answer
0answers
Does the mains adaptor ad a12250lw have a fuse
NO! Usually an electrolytic capacitor is defective.
12/17/2013 1:00:22 PM • Casio Privia... • Answered on Dec 17, 2013
2answers
Is there anyway we can turn the on board speakers off so that we can go through our sound system?
Plug a set of headphones into one of the PHONES jacks on the left side of the unit.
12/17/2013 12:57:10 PM • Casio Privia... • Answered on Dec 17, 2013
How can I do an internal factory reset for my
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
12/17/2013 12:41:28 PM • Casio Privia... • Answered on Dec 17, 2013
Does the casio AD A12150LW MAINS ADAPTOR HAVE A FUSE INSIDE
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
11/26/2013 1:53:13 AM • Casio Privia... • Answered on Nov 26, 2013
My Casio Px 330 keyboard
This is a problem with one of the two contacts for that key. The contacts close at different times as the key is depressed and the time it takes between is measured as velocity which is used to control the loudness as in a regular piano. The contacts are conductive rubber pills. After a lot of dis-assembly you can clean them with 99% isoprphyl alcohol and Q Tips. Clean both the pills and the circuit traces on the board they are pressed against. Be very careful of the ribbon cables between the halves of the case.
11/4/2013 4:07:52 PM • Casio Privia... • Answered on Nov 04, 2013
Casio px-330bk keys pitch sharp top half of keyboard
The problem you're encountering is actually a feature, called stretch tuning. While real pianos are tuned in this way it's meant to sympathise with their natural 'organics' and might sound wrong on a digital instrument. The solution is to turn stretch tuning off. The manual should be able to tell you how.
9/11/2013 7:28:36 AM • Casio Privia... • Answered on Sep 11, 2013
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
9/14/2012 9:28:21 PM • Casio Privia... • Answered on Sep 14, 2012
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
43 questions posted
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
anyway turn board speakers off go our
  • Music
