Battery restart
Bad battery 99.9%
the changer is NOT in the A/c pack ,the PACK is only power pack.
so replacing the motherboard first is silly.(where charge chip resides)
that huge battery can fail in 1 year. if unlucky or abused, gee its a battery? take it out and test PC.
next would be bad AC power pack(costs $15 is why)
why not run on AC pack only, not big battery.
then if that runs (it can for eternity if you want)
then try a new battery..last if all else works, ok?
1:Big battery, and keep it out. (they can short too)
2: run on AC, ok now? sure.
3: now buy a battery and test RTC coin cell at 7 year mark in time.
the battery simple falls out the bottom , lever slid.
why not do that first>?
page 35 in your manual..
https://www.manualslib.com/manual/500036/Lenovo-Thinkpad-X41.html?page=59#manual
batteries can fail fast even in 1 year.
per the makers of the battery if abused,
did yours
last 13 years? 2005 to now? or just now shorted.
all unserviced or found old PCs 13 years old
have 2 bad batteries
the big one and the coin cell.
the latter is mandatory, and the big one is optional
ok?
this pc is 13 years old today
both batteries (ignored) for 13 years , are both no good now, if not true this.
list them at (under world record battery life)
http://www.guinnessworldrecords.com/sear...
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
SOURCE: Tablet PC 2005 Input Panel won't work.
Are you pressing down firmly enough? If not, sounds like the digitizer may have a problem... The digitizer is the layer in front of the lcd, it's job is to pick up the signal from your pen and send it to the motherboard. The motherboard should have two connections to the screen, one to the lcd itself and another to the digitizer. If you remove the screws on the bottom of the tablet you can take off the keyboard and see if both are connected right.
SOURCE: can i use a bamboo fun stylus on a x41 ibm tablet
Yes you can. You will not be able to use the tablet pen however while the stylus is plugged in
SOURCE: ThinkPad X41 Tablet PC: reinstalled the x41 using xp.. cant get the video...
Here's the link where you can download the driver for XP. Make sure you select the correct family. X41 has two types of unit. Tablet and regular laptop. Make sure also to choose the correct type and model. If you are not aware of this, it is actually at the white sticker at bottom of your laptop.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: need to reset user name & password for lenovo thinkpad x41 tablet
Windows Password Genius can help you to reset user and password at the same time.
Was this helpful
give me rate
