Check to see if there is a plastic tab fitted at the factory that has yet to be removed on the battery contacts....check for corrision...clean contacts...then see if it will charge or switch on...if it doesnt then you need to consider if the battery is dud...it should still turn on minus the battery if it is receiving power externally..if it doesnt then the smd fuse has probably blown, this can happen by power spikes, or using an incorrect charger or a third party battery instead of the one supplied by the maker.
SOURCE: Won't Turn On/Charge
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
SOURCE: Acer Aspire 5100 won't connect to secure Verizon Mifi 2200
Delete the previous wireless connection than changed the key in router and than try to connect.
SOURCE: my samsung smooth phone wont turn on but it is
try formatting the phone memory....if that fails try updating the firmware! Remove memory card in all tests
SOURCE: can i get xbox 360 live using mifi 2200
Get Help with Flashing Red Lights for NXE Xbox 360 | Xbox Support this site has all you needs
SOURCE: How come my battery wont charge on my brand new
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
