p
pau phoenix Posted on Jul 05, 2018
Screen on xante platemaker 4 says fatal: 8034f99c
2 Related Answers
Anonymous
  • Posted on Aug 18, 2010
SOURCE: Manual tray feed problem on Xante Platemaker 3 laser printer
You may have to change your settings in the program you're printing from to say "tabloid" instead of the plate size. You basically set everything to make the printer think it's printing 11x17 paper instead of a plate. The only thing I leave the same as a plate is the setting in Quark that says, "Media Type". I leave it on Polyester Plate.
kirkx
Kirk Augustin
  • 2019 Answers
  • Posted on Mar 28, 2011
SOURCE: Have a Xante Platemaker 3
Make sure you follow all the places that paper could jam. While it says "exit", that could be misleading. It could be there is paper in front of or after the toner plate.
Just a small torn scrap could do it.
But if there really is no paper, then it would be a sensor.
Most sensors are just light contact switches, and are easily bent or jammed when you pull paper out.
But there can also be light sensors that can just get dirty and need to be brushed off.
Cover open?
Dear its your Platemaker 4 front cover open massage i think please check its right behind the front panel,its not easy to check it first removed the panel cover side cover after that formatter board,fuser assembly you can observe that its communicate with gears,found in main engine there is small lever who controlled front cover,hope you understand.
thanks.
Screen Setup
Do you mean for screen printing? How many colors? You need to assign specific LPI's, angles and dot type depending what you are trying to print. Your art also might need to be set up better. Can you send link to image and print?
Is there a driver for platemaker 3 that works with Mac 10.6.4?
Platemaker 3 supports Mac 8.x-10.4. Check out their support site from the link below:
http://www.xante.com/support/pm3/
2helpful
2answers
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
2helpful
3answers
Screens Picking off on press
the problem is due to the fuser not to anything else seems that the fuser do not heat up the toner enough, what i did is to run the plate twice , as blank of course . it did the trick for my press.
Top Xante Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
