20 Most Recent
Xante CL30 HSE Laser Printer Questions & Answers
What does error code 032
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Fatal error 20
this is a memory issue. remove the memories an dopen the printer if it open ok, close it and try putting one memoery at the time.
Paper keeps jamming in the
if you have many jams in the fuser probably the roller have dry toner attached to them. print a heavy paper - 300gsm - without any color, just a small dot. see if the paper comes out of the fuser and if it;s dirty or not. repeat that until the pages com out clen - both sides. then print what you have again,
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
How to replace fuser fan on xante cl30 hse
it's not easy to describe it. The fuser fan cover has some screws, remove them and then remove the fan, it's a little tricky. From my experience, the new fan has small cables. What i did is to cut the cables of the old fan and attach them to the cables of the new one. My suggestion is if you don't feel confident, leave to a more experienced technician.
