20 Most Recent Xante Ilumina Digital Color Press Printer Questions & Answers
registration is slightly off. I'd try re-setting the drums (take out and put in again). If you have another cyan drum, would also try that. Transfer belt would be next
Xante Ilumina... | Answered on Sep 28, 2016
Dear when your paper tray is goes down your paper tray sensor is close printer detecting paper out,please fix your tray your printer is working normally.tray never drops little bit its fixed hope you understand.
thanks
Xante Ilumina... | Answered on Aug 18, 2016
sorry I can't help with this problem
Xante Ilumina... | Answered on Apr 22, 2015
it may be what you are printing your pictures on try different printing materials
Xante Ilumina... | Answered on Apr 14, 2015
You have two (2) sensor that have to be made, the first one is on the bottom of the feeder and the other one is at the very top of or near the feed roller. When you block the bottom sensor the feeder should move up. If the feeder does not move up their is a problem with the cable that connect to the printer and the feeder or it could be the Motor control board that is inside the printer itself. I would check the connection first, covering the bottom sensor if it does not move up most likely the control board is bad. Also make sure that the feeder in position switch is also made by the feeder plate.
Xante Ilumina... | Answered on Mar 04, 2015
The motor control board handle few sensor within the feeder. Check the cable telephone for proper connection. And at the very top of the feeder there is a sensor and one on the feeder itself at the bottom. If those sensor are good the problem could be the motor control board.
Xante Ilumina... | Answered on Feb 02, 2015
Sub CPU I/F Error
Check Connection of the Motor Driver Board. Replace the Motor Driver Board / Engine Control Board
Xante Ilumina... | Answered on Oct 07, 2014
CU Resident RAM Check Error
Replace Fiery PCB (must move EEPROM to new board)
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
131 code
LED Head Error
131= Yellow Head
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
Ilumina Transfer Belt Replacement
167 questions posted
Top Xante Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
 Mike M
Mike M
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xante Office Equipment & Supplies
Most Popular Question
188 fatal error
  • Office Equipment & Supplies
