During periods of high humanity, there will be considerable condensation (water) forming on the evaporator (cooling) coil. The A/C cabinet of a window unit must be slightly tilted outward to allow the accumulated water to flow toward the condenser (outside) coil and fan. The unit is designed to allow the outside fan blades to pick-up the water and throw it through the condenser coil fins. The cooling effect on the condenser coil actually improves the inside cooling efficiency, plus lowers the operation cost.
During periods of high humidity, there will be considerable condensation (water) forming on the evaporator (cooling) coil. The A/C cabinet of a window unit must be slightly tilted outward to allow the accumulated water to flow toward the condenser (outside) coil and fan. The unit is designed to allow the outside fan blades to pick-up the water and throw it through the condenser coil fins. The cooling effect on the condenser coil actually improves the inside cooling efficiency, plus lowers the operation cost.
They are not filled with water thats the condensation that it is making, its all good, keep the temp at a steady rate, when you get it ice cold then shut her down it makes moisture which then is water.
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer
Affairs Representative from within the United States, please call
1-877-254-4729
SOURCE: We have a 2007 Amana
That is a normal function of the air conditioning. Nothing to worry about, it is removing humidity from the air.
SOURCE: Bought Amana 7000 BTU portable
Self absorbtion means that the water is evaporated by the blower blowing air over the condensation. On very humid days there may be too much water to evaporate. There should be a drain outlet on the back and it may be blocked. Clean it if you can find it.
SOURCE: Amana portable air conditioner will not turn on.
drain the water. Same problem, it fixed it. alot of water in there Be careful
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
