Does it pay to fix it or will it be more economical to buy a new one even though it won't be as large since they don't seem to make that size anymore?
The gasket will allow the unit to make temp and shut off up to you about repair verses replacement
Try sealing the door with tape to see if the thermostat will work to turn it off.
My Kenmore upright freezer had a separate cross seal down quite low, on the freezer not the door. I reversed the door seal so the damaged top part was below the cross seal and voila, no more leak.
If it needs a thermostat I suggest getting it sealed first. Mine was only 10 or so years old but Sears Parts said seal no longer available. Good luck
SOURCE: amana BX22RW Freezer Compartment Icing
Ya hit it right on the head. Sounds like a classic "pulling in moisture" problem. See if you can seal that air leak any way you can. That moisture can freeze up air channels and block the refer compartment from getting cool air from the freezer compartment eventually.
SOURCE: broken thermostat on Danby DCF1019W chest freezer
Take your model number of the unit to your appliance parts house and they can cross reference the t-stat. you could try this web site to see if you can find one
http://www.wsconet.com/
SOURCE: how to fix blown head gaskets on a 1996 tahoe
its not the head gasket it is the intake manifold gasket and you can bypass all the throttlebody seal by removing all the wires and taking it off these are very bad at doin this cause they have a plastic gasket look up some pics on it it took my and a friend bout 5 to 6 hours to do but the shop wanted 700 dollars so that saved some money.
SOURCE: i need a new printhead for a canon pixma mp 760
www.officestoredepo.com for all print heads.
SOURCE: Head gasket is damaged. 2005 Nissan Sentra, 1.8
i have a 2005 1.8 nissan sentra.i rplaced the radiator becuause it was leaking.so when i did i took it for a test drive and the needle went to hot then back down to middle ways between the C & H BACK IN FORTH.so i replaced the thermostat. now as far as i can tell it is staying in the middle of C & H. i can't feel no water though cerulating through the top or bottom hose of the radiator. so now that i told you what i done so far my question is???? ( my heater is not working in the car it is blowing out cold air & i left the car runnng for about 45 min. even took it up and down the road.still cold air.what do you think i need to do?????????? )
