Hisense Model : HX32N2176H 32" Led TV
Please, I have this same tv but I discovered that the AUX is not working. can any one advice me? thank you
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
I hope this helps.
SOURCE: Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
SOURCE: connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
SOURCE: i have lenovo ideapad y510
Hi er_gauravpra,
I see you want to use an HDMI connection for your Video from your Lenovo Y510.
I have checked information about the Y510 and it does not have the Technology of HDMI on the Y510 system of Lenovo, Y510 system only have the VGA port where in you can use a VGA cable to get video output to an External Monitor.
Regarding the issue about HDMI I have not seen any Converters yet that can be bought from anywhere to convert VGA to HDMI and I believe that will not be possible since VGA is a lower type of video output than what an HDMI can.
I do apologize but the Y510 systems does not have the HDMI technology to on it.
I hope this clarifies everything about your Query.
Have a nice day
mvincentc
SOURCE: how do i connect my hdmi cable from my ibuypower desktop to my sansung led tv?
Make sure the input on the TV is set to hdmi port 2. If it doesn't automatically view on the TV, you have to go into the graphics card adapter settings to set the view to an alternate monitor (your TV). Normally there's also a hotkey command as well (normally one of the F# keys) to switch between displays
