20 Most Recent Hisense 50 Class LED HDTV - 1080p, 1920x 1080, 120Hz, 3x HDMI - LTDN50K360GUS - LTDN50K360GUS Questions & Answers
If you are connecting a computer using a HDMI cable, the audio does not go on the cable. You must use a stereo audio cable to connect the TV to the PC.
Hisense 50 Class... | Answered on Jul 23, 2016
here's the spec's for the 50" Model, it shows a headphone output and it will certainly be a 3.5 Jack: HISENSE LTDN50K321UWTS 50 inch 4K Ultra HD Smart LED TV Freeview
Hisense 50 Class... | Answered on Jan 21, 2016
Hisense can be unbelievably expensive on parts, consider a salvaged part with a warranty from shop jimmy or similar, much cheaper than the manufacturer but you will have to fit the panel or find a capable friend
TV Parts Universal TV Stands DLP Chips ShopJimmy
Hisense 50 Class... | Answered on Jan 20, 2016
http://hisense-usa.com/support/manuals/50H3_us_M_en_man.pdf
not sure on your model number
go to http://www.hisense-usa.com/support/manuals.asp
then search on model number or serial number if 50H3 is not your model number .
Hisense 50 Class... | Answered on Nov 27, 2015
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Hisense 50 Class... | Answered on Nov 17, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Hisense 50 Class... | Answered on Apr 12, 2015
Change the batteries first. Then see if you can turn on the TV using the buttons on the TV. If the TV still works then best get a universal remote. I really like my Harmony brand.
Hisense 50 Class... | Answered on Feb 13, 2015
Each manufacturer creates their own codes, so you will have to look at the manual for the Comcast remote, or on their website.
Hisense 50 Class... | Answered on Dec 03, 2014
If panel lock is being stetted to ON, the front panel buttons on the TV won't work. If you want to make it a system reset, you have to enter its service mode option. You should have its remote control to make it this Factory Reset.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Hisense 50 Class... | Answered on Jul 07, 2014
This is likely a simple settings issue.
A lot of people don't realize that backlight settings can affect the picture.
Go to the menu (press menu on your remote)
The menu will show picture options. Just toy with different settings until you find what you want. It may be on a preset setting that doesn't work. If you are in a bright room, you will need to increase brightness and contrast and perhaps backlight.
Usually an unclear picture is due to the contrast, backlight, and brightness settings being too low. You can also increase sharpness.
I suggest a contrast setting of 70, a brightness setting of 60-80, and a backlight setting of above 80.
Good luck.,
Hisense 50 Class... | Answered on Mar 08, 2014
Delete the App, unplug the television, count to 10. Reload the app and try again. It sounds like it has become corrupted. Also check for updates to the television.
Hisense... | Answered Yesterday
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
To do a factory reset, you should have a remote control.
Hisense... | Answered 2 days ago
Hisense 50 Class LED HDTV - 1080p, 1920x 1080, 120Hz, 3x HDMI - LTDN50K360GUS - LTDN50K360GUS Logo
17 questions posted
Top Hisense Televison & Video Experts
Paul
Steve Allison
Steve Allison
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
best quality picture
  • Televison & Video
