20 Most Recent
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Questions & Answers
Cannot connect to my wireless network
Recheck your router to see if the mac address of the TV is listed on the wifi setup page. On the TV, make sure the router password is entered correctly
Why doesn't it turn on?
There could be an issue in the power supply. I am assuming here that there is an external PS or power brick and some call it that plugs into the tv. Crack that open and take a look at the caps which look like little tubes or little boxes if any of them are blown open, bloated, or misshapen then that it more than likely your problem. Common misconception is that power strips safe guard you from power surges, but unless you paid big bucks like over 150$ then you have no surge protection other than your homes breaker box. Power supplies are easily replaced as they are the most common failure in televisions. If you don't notice anything that looks off, try buying a power supply from somewhere reputable like amazon.com where you can buy a power supply and return it if there is no issue. If you do find something let me know and I can help you find what you need.
What is the code for wizard 2 remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
How to set up forutube
Recommend using the installation and setup procedures straight from the manual. Unfortunately, I cannot access the manual, but I recently set up a new Smart TV and found that the manual is essential to making it easy and painless. The added benefit was that I learned how to properly use my TV easily.
Good luck,
Remote and manual buttons don't work
If the panel lock is set to ON, the panel buttons won't work. If the remote control or the infrared sensor inside the TV is faulty; the remote control won't respond. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
