SOURCE: Micro-sd card capacity
absolutely. the first time you pop it in, your phone will ask you if you want to format it. select 'yes' and then you will find several new folders for pix, flix, music, etc.
SOURCE: micro sd card removal
You'll have to either push it into the phone to release it or, worst comes to worst, find some tweezers and go to work.
SOURCE: How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
