Alot of times you can turn the water off to the toilet and the tops of the fill valves usually pop or screw off. then if you put a small cup over the top of the fill valve you can turn it back on and flush the debris out and put it back together. if its a fluid master type you can pop the top off it. and turn the float arm a 1/4 to half turn and the whole top will come off
Thank you Mr. Guru...My "pump" is a Hunter...screwed off
There was some debris. The water valve had the most.
I removed the flexible hose (not flexible in mine) and
turned the water back on a bit...out came major debris.
So the toilet now works...BUT it won't stop running....
Now I have to fix that...this is the powder room tight
spaces..oh, well...what did I have to do on a Sat. afternoon anyway....Thank you again....vsp
