20 Most Recent
Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges Questions & Answers
The Toto maple softclose round
Try buying some cheap foam tape and place some on both the cover and the seat. Any hardware store should have it. Something similar to this:
http://www.google.com/products/catalog?q=foam+tape&hl=en&safe=off&client=firefox-a&hs=8cx&rls=org.mozilla:en-US:official&prmd=ivns&um=1&ie=UTF-8&tbm=shop&cid=10171339953270674152&sa=X&ei=Cu_VTfaCKIfYgQfIhrmvBw&ved=0CJgBEPICMAE&biw=1280&bih=548#
I can't figure out how
Hello. The top hardware behind the seat does open. like a little door on a plastic hinge. Inside you will find a large head screw. Use a small flat blade screw driver to pry up the cap and then a large flat blade screwdriver to tighten the plastic screw. Repeat with the other side.
Toto Neorest 600 issue of low water pressure
page 35 of your instructions. Don't have it, here is a link copy and paste
https://www.totousa.com/filemanager_uploads/product_assets/OwnersManual/0GU9001R_NEOREST_600_EN_OM.pdf
7/8/2023 3:46:16 PM •
Toto Home
Answered
on Jul 08, 2023
Toto washlet s300 has developed slow leak from behind brass connection and plastic.
If you are able to identify the source of the leak, you may be able to fix it yourself. If the leak is coming from the brass connection, you may need to replace the connection or tighten it. If the leak is coming from the plastic, you may need to replace the plastic part or use a sealant to stop the leak. If you are unable to identify the source of the leak, it is best to contact a professional plumber to help you diagnose and repair the issue.
3/16/2023 9:59:53 PM •
Toto Home
Answered
on Mar 16, 2023
The stream on "Rear" is weak on my new Toto Washlet GL since I got it 1 week ago. The "Soft Rear" setting works OK, but the normal Rear wash is no stronger than the "Soft" setting.
It sounds like you may have a problem with the water pressure for the rear wash setting on your Toto Washlet. Here are a few things you can try to troubleshoot the issue:
- Make sure that the water supply hoses for your washlet are securely attached and not kinked or clogged.
- Check the water pressure at the source (e.g., the wall outlet or the valve under the sink). If the water pressure is low, that could be the cause of the weak stream.
- If the water pressure is fine, try cleaning the nozzle for the rear wash setting. Sometimes debris can accumulate in the nozzle and cause the stream to be weak.
- If none of these troubleshooting steps help, you may need to contact Toto customer service for further assistance. They should be able to provide you with additional guidance or arrange for a service technician to come and check your washlet.
1/6/2023 8:31:31 PM •
Toto Home
Answered
on Jan 06, 2023
