Beware of "Glenn Marsh" links posted on many questions - apparently mostly malicious web sites but links not blocked by FIXYA. Fake name and may be connected to fake Stephen King on FIXYA.
If your computer was infected by a virus by going to the known virus site, which is falsely described as an HP support site, report it to authorities in the United States for prosecution.
https://www.ic3.gov/complaint/splash.aspx
The users looking for technical help they are free to contact at HP Stream 14" Laptop support number +1-888-687-4491 it is a toll free number with 24 hours 365 days availability. HP Laptop support is offered at reasonable costs in US and Canada regions. 1 8886874491 HP Laptop Technical Support Phone Number for Repair
Hi Kim
HDD failure...101. HP 2006 and newer.
backup first, ok.? if not tool late, google how to backup your hDD
then power on
and hammer the F11 key,
this activates the HP recovery, pick repair startup files.
if that fails, buy a new HDD or SSD (better)
and reload the software, per HP instructing
oh, btw, fixya is NOT HP.
hp is hp
https://support.hp.com/us-en/
Remove and reset (replug in) your HDD if that doesn't work replace the hard drive
SOURCE: laptop does not recognize my mini dv camcorder
You need a video editing program to see it. Pinnacle studio works with your camcorder.
SOURCE: Windows XP compatibility with Celeron M575 Processor ?
yea it can be installed on these computers, you have to go into your bios and disable sata support, then delete and fromat the partion and then insert your xp disk and voila... this computer i'm posting from is a compaq with the celeron m575 that i installed xp on...
SOURCE: My sound driver is not
Go to the web site of what ever PC you have ( Dell, HP or what ever the PC is ). At the web site you should find section that says drivers and support, or something like that. It will have you select your make and model. You should find the correct drivers there.
Hope this helps.
Good Luck
cookEmonster
SOURCE: Dell Studio 15 runs slow... My
Check the boot processes in the from your systems control panel and look for unnecessary boot time services. Such as an anti virus boot scan and similar processes. Sometimes it is caused by the network card driver. Start your computer in safe mode and select the selective start up option and disable each service one by one (non windows) to find out which one is slowing down your boot process. It usually due to a boot scan, a faulty driver, or an invalid or corrupt registry entry. I highly doubt that you are infected with a virus and it is due one of the issues listed above.
