Switchless
You can use a ohm meter to find out what does what before you attempt to hard wire it.
Jay the pool pump guy longwood Florida
saw mod 5201na switch wiring diagram Google Search
SOURCE: Switch diagram
as u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
SOURCE: I have a 10 inch ryobi miter saw, ts251u, the
Bad news, the swich you need is part number 350001 and it is no longer available. Might I suggest that if you have a local repair center take the switch and see if they can match it up with another mfr. switch. Some of the Milwaukee mitre have switches like you describe. Sorry I couldn't give you the answer you needed.
SOURCE: Makita circular saw 5007n, it will only run when
Great!! Could you please rate my solution as a "problem solved"?
I would greatly appreciate it.
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
