SOURCE: buick regal wont start in
I would take a listen by your fuel filler door and see if you can hear it engage when you turn the key into the "ON" position. You will need someone inside the car to turn the key, and another person by the fuel door to do the listening. If you don't hear the pump engaging, you have a problem with your fuel pump. It is either bad, or not getting enough of a connection. Nine times out of Ten the fuel pump is bad and needs to be replaced.
Hope this helps you out.
SOURCE: Hard to start by sub zero temp
oh oh oh, thats why father christmas uses a horse,,,
dieal engines dont get very good starting when its realy cold,,,
the heater light may go out but are they getting realy hot???? if not it wont start very well, my trick is give it twice the heat turn the kye to pre heat when the light go's out very quikly turn it off and back to pre heat again,,, when you have dont this the second time start her up,,,
now watch her go??? the heater relay should hold the heaters on for a minuet or so even though the light has gone out, so your could be fulty and it turning them off to soon, and a biseal with out heat is a dead duck if its cold,,,do as i all ways do if its cold,,,,twice the heat then start her up, it takes far less out of the battery that cranking up twice
SOURCE: Sub-zero 550 Refrigerator working, Bottom frezer
Need check cold control and compressor start relay.
You would have checked the charging system before replacing the alternator, so I will assume the charging system is good.
If the battery is being discharged overnight or over a few days, you would need to disconnect it and check every circuit on the truck to find the drain.
