SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message
Solution: Perform a RAM Clear
Make Printable
Email this page
Performing a RAM Clear will restore all of the WorkCentre's
settings to the factory defaults. It will also clear all faxes in
memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System
ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print
out your Phone Book before performing the RAM Clear, to assist you in
reprogramming your Speed Dials and One-Touch Buttons. It is also
recommended to print out your System Data List to assist you in
reprogramming your system settings. If you are not sure how to print
your Phone Book or System Data List, refer to Related Items at the
bottom of this page.
To perform a RAM Clear:
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
SOURCE: Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset
code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
SOURCE: WorkCentre M-24 Color Copier: I WANT TO RESET XEROX 3140...
Reset printer using reset software. [email protected]
