SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: interior light staying on in GE JVM1790 and
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Since
it's less than one year old, it would be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find a
GE-authorized servicer by calling GE Appliance
Service at 1-800-848-7620 or here.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
SOURCE: microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
SOURCE: Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
