20 Most Recent GE JVM1790 Convection / Microwave Oven Questions & Answers
Light wont turn off on GE profile
WHEN THE BULB BLEW IT PROBABLY BURNT OUT VIOLENTLY AND DAMAGED THE RELAY ON THE MAIN BOARD THAT CONTROLS IT. WILL PROBABLY HAVE TO REPLACE THE MAIN POWER BOARD WHERE THE RELAY FOR THE LAMP IS LOCATED
4/19/2018 1:52:24 PM • GE JVM1790... • Answered on Apr 19, 2018
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
11/30/2017 7:31:55 AM • GE JVM1790... • Answered on Nov 30, 2017
I have a GE Profile
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point. Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
10/26/2017 8:54:54 PM • GE JVM1790... • Answered on Oct 26, 2017
0answers
0answers
The microwave heat works but the convection heat does not
you need to buy a new one because it is broken.
12/27/2016 1:48:12 AM • GE JVM1790... • Answered on Dec 27, 2016
2answers
Dim display panel
Hi. The service manual is here - perhaps your solution is here too: GE JVM1790SK Service Manual
7/16/2016 11:12:14 PM • GE JVM1790... • Answered on Jul 16, 2016
Clock displaay very dim
You would probably have to replace the control panel circuit board, or send it in for repair. There are companies that repair these for about $39, or less. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/3/2016 11:52:20 AM • GE JVM1790... • Answered on May 03, 2016
2answers
Why won't it heat?
check three thermal fuses.
5/3/2016 11:46:42 AM • GE JVM1790... • Answered on May 03, 2016
I replaced the line fuse in my GE JVM1790SK01 microwave, but it blew again as soon as i tried to start it. the display came on, but blew the fuse as soon as i hit start i start.
Yes... Not very sophisticated... but that is what these beauties do when their Magnetron finally gives up the ghost (major cause). They are wonderful machines! Magnetron AP3883525 (WB27X10865)... approximately $104... at appliance parts pros If you love them... you know what you need to do. and Fuse: Very good... you have an excellent beginning. Keep up the good work. These "parts" can be EARLY failed... by putting very small pats of butter... or ting amounts of fluid. I watched my sisters grand children using her "NEW" microwave to soften pats of butter. A word to the wise wasn't heard... and now she has another "NEW" Microwave. Good luck... save $$$
1/3/2016 10:10:20 PM • GE JVM1790... • Answered on Jan 03, 2016
7 yr old unit emitting burning smell. Everything still works. Is it worth trying to get repaired or just buy a new one.
is the burning smell just when you use the convection oven or when you use the microwave , reason I ask is that if its only coming from the convection oven then chances are you have something melted on the heat elements , this can be cleaned off with a dry brillo pad
11/21/2015 12:08:19 AM • GE JVM1790... • Answered on Nov 21, 2015
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
3/2/2015 5:44:06 AM • GE JVM1790... • Answered on Mar 02, 2015
How will you let me know when question is answered
You will have to follow your question so that if anything is written on that question , you will be alerted on your e-mail add
2/19/2015 7:26:18 AM • GE JVM1790... • Answered on Feb 19, 2015
Where is the inline control panel fuse on a ge profile jvm1790bk microwave
They do have a main power fuse behind the control board.
11/22/2014 6:21:52 AM • GE JVM1790... • Answered on Nov 22, 2014
GE JVM1790 Convection / Microwave Oven Logo
93 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
oven goes when door shuts
  • Microwave Ovens
