20 Most Recent GE Advantium 120 Convection/Microwave Oven Questions & Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
GE Advantium 120... | Answered on Jun 12, 2019
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts (such as "button") by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you find you need control panel repair, we do that nationwide for $39.95 in most cases. See: http://tinyurl.com/yzjozk
GE Advantium 120... | Answered on Jan 05, 2019
If you wish to get some details about microwave oven; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
GE Advantium 120... | Answered on Jul 30, 2018
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
GE Advantium 120... | Answered on Dec 01, 2017
Use aluminium foil to cover the baker. But only in convection case, not for micro waves cooking !
GE Advantium 120... | Answered on Nov 14, 2017
Yes but you must remove the oven cover.
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
GE Advantium 120... | Answered on Nov 05, 2017
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
GE Advantium 120... | Answered on Feb 02, 2017
Try opening your microwave and look around for sensors.
GE Advantium 120... | Answered on Jul 21, 2016
It may be the servo motor that powers the turntable or the belt has snapped or come off. It is unlikely that you can get to the motor as the case is fitted with security screws. If so, you will need to take it to a service engineer.
GE Advantium 120... | Answered on Mar 18, 2016
Same Problem - baking when all power appears to go out - but the AC power is plugged in and it is good: This is a known manufacture defect for the Advantium 120 model SCA1000. But, don't expect Sears or GE to take care of you. Short version: A Thermister that cost under $1.00 to manufacture and is known to be defective in this and other products needs replaced. But, the schematic, the GE Repair Center, and local GE repair center don't document things right and don't have the part. I won't buy GE again since they can't control the manufacture of fire safety standards in the Korean plants. This part will be defective after about 3 3/4 years of being plugged into the wall. So much for your optional 3 year warranty! Read the entier solution before trying this at home: 1. Remove the button front panel where the display is at. The ribbon cables to the front panel will allow room to peer inside. There is an envelope taped to the side with the schematic. 2 On the Schmatic Diagram (not the wiring diagram) on the bottom see CN6 - with two thermistor. Now look at your actual wiring. Guess what! GE did not even put the right wiring diagram in your maicrowave! GE shows a 3 wire device. Actually you will find 2 different 2 wire devices! Thanks GE, I took the part and the schemetic to an Authorized GE repir parts store. They checked with the GE parts manager in Dallas. After paying the GE shop $49.87 for the part order, after 6 follow up calls and 3 weeks, they send the wrong part on the schematic, not the part that I brought in that is actually in the oven. 3. The part that is bad in your oven is a thermister that cost about $0.14 to make. There are two of them. There is two wires that attach to them. If your unit overheats, it shuts down the power for safety. What happed is that one of the two thermisters is opened (defective). They are screwed on to the service to detect heat. The numbers on the can are PW-2R (PWC PW-2). One of mine measures about 44 ohms, the other exact one is open (infinate resistance). It is two wires attached to a round cylinder about 3/8" wide - a bracket holds it against a flat surface with a single phillips screw. Its purpose is to detect heat, if things get too hot, it switches from on to off. When they go bad - it stays in the off position. The effect looks as if you don't have your microwave plugged into the wall. 4. Ordering the PW-2R. GE has no record of them. Thanks again GE! HP laser Printers used them on one model. This little part caused all of the printers to go bad. From an internet article, it appears that HP Printers no longer use this part. In the case of GE, it is my opinion that they got the microwave safety approved then switched out parts for manufacturing. Where is Consumer Reports when you need them? 5. I am still searching the Internet for a substitute part. One Sears repair person quickly (and unofficially) told me that it would be the Thermister, a known problem before I started. This is my worry: If the part is not available, and repair persons are making quick fixes (for about $100), that they are simply cutting and tying the connector together. In otherwords, they are taking out the safety feature rather than replacing the safety part. If I find the part, I will post it on here. But, after a couple of hours of searching, and checking with various part shops it does not look too good. It does not take much searching on the Internet to see that the GE Advantium is widely known for poor manufacturing standards and about a 4 year life-cycle. When one considers what it cost... it appears to be rated as a bad investment to trust GE applicances. By the way - the schematic and other parts indicate it is manufactured in Korea.
GE Advantium 120... | Answered on Feb 01, 2016
GE Advantium 120 Convection/Microwave Oven Logo
772 questions posted
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
turntable not turn replaced rotating
  • Microwave Ovens
