20 Most Recent GE JVM1653 Microwave Oven Questions & Answers
Microwave door has burnt patch: is it safe to operate?
From your other post:
The paint should be available at big box stores like Wal-Mart, home improvement centers like Builder's Square, Lowe's, or Home Depot, or hardware stores or local appliance parts stores.
You can order the plastic sheet (called the "door film") here. It is part # WB06X10490.
Be sure the mesh is clean and dry before installing the new film.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
10/28/2022 5:05:23 PM • GE JVM1653... • Answered on Oct 28, 2022
39answers
Microwave shuts off after a few seconds
Nov 22, 2007. I also had the 3 second shut off problem with my G/E 1650 MWO. Read all the above and tried them all. Finally I just took a 8" x 8" piece of Reynolds Wrap Aluminum foil and but it in an zip lock bag and placed it behind the control panel. It's been working for 2 weeks now. Just take out the 2 screws that hold the vent across the front right above the door. Next on the right side is one screw, take it out and then gently lift the control panel (panel with the buttons) about 1/2" and it will fold out and stay there. put the zip lock bag inside. Close it back up. I'd test it before replacing all the screws. You don't need to un-plug anything. Just don't stick your fingers on all the exposed parts...Mine works great now and didn't cost $0.10.
5/22/2019 5:06:29 AM • GE JVM1653... • Answered on May 22, 2019
0answers
Itook my ground off of my microwaveand it just blinks
Some control panels will malfunction if the unit is not grounded.
Additionally, one side of the high voltage supply to the magnetron is usually tied to the cabinet. So, if not grounded, you have a "floating" 4000 volts. It's possible this could be a dangerous situation if something else failed, such as the transformer. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/6/2016 12:33:12 PM • GE JVM1653... • Answered on May 06, 2016
Vent fan filter??cleaning,etc does not seem to pull air out as it runs
If this is a new installation, or if this ove is new to you, the following may apply: on some ovens the vent fan can be flipped to either exhaust air out of the house, or re-circulate it. Could it be in the wrong position? You would have to take the oven down to determine this. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/6/2016 12:26:25 AM • GE JVM1653... • Answered on May 06, 2016
0answers
Microwave interferes with TV
Take one fluorescent light-bulb -- not connected to anything -- and a darkened room. Start the microwave, and see if any emissions from it activate any of the fluorescent materials inside the light-bulb.
3/16/2014 12:48:03 AM • GE JVM1653... • Answered on Mar 16, 2014
0answers
0answers
There is power to unit, but food will not heat-up
In my case, it was a high voltage fuse that had burned. The reason for that is most likely a shorted diode ($3 ebay) or shorted capacitor ($12 ebay). They are easy to locate and cheap to replace. You will need to remove the cover and use a multimeter to find the faulty part.
1/13/2014 6:01:02 AM • GE JVM1653... • Answered on Jan 13, 2014
Cannot remove cavity light in bottom of microwave
REPLACE TOUCH PAD
1/13/2014 1:49:11 AM • GE JVM1653... • Answered on Jan 13, 2014
Stops after 4 mins
Can you hear the "whirl" of the fan? It is possible the fan is not turning & cooling the oven therefore it will shut down when it reaches a certain temperature. This could be caused by a supply fault to the fan or the fan motor, either way it would need to be tested by a qulified engineer.
11/11/2013 12:25:09 AM • GE JVM1653... • Answered on Nov 11, 2013
Turntable stopped working
I have critical safety and disassembly info at my site, linked in my FixYa listing here: http://tinyurl.com/yzjozk You can find handy exploded views and order the motor here: http://tinyurl.com/gv383
7/20/2013 11:40:35 PM • GE JVM1653... • Answered on Jul 20, 2013
Maytag microwave auto heat then turns off
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.Please post a new help request with that and more detailed symptoms.
4/16/2013 5:21:41 AM • GE JVM1653... • Answered on Apr 16, 2013
My ge jvm1653 BD 001 has a burning wire smell
The power supply is overheating and needs to be checked asp, this is a fire hazart and a safety issue.
5/19/2012 3:06:20 PM • GE JVM1653... • Answered on May 19, 2012
Where is the fuse located in a GE spacemaker xl microwave oven
Unplug microwave, remove top, follow wiring from the keypad area to the circuit board, look for a silver rectangular high voltage capacitor, discharge across the two points, and near by look for a small fuse clipped in, pop it out and replace with same current rating. If fuse blows! one or two door switches are probably bad and will need to be replaced.
3/18/2012 4:49:40 PM • GE JVM1653... • Answered on Mar 18, 2012
Running micrwave with no food inside
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time. Hopefully one of other experts will be able to provide you with a real solution. Thank you for using FixYa.
2/6/2012 8:25:45 PM • GE JVM1653... • Answered on Feb 06, 2012
GE JVM1653 Microwave Oven Logo
69 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
microwave shuts off after few seconds
  • Microwave Ovens
