First thing I would do is change my password. Some websites will not allow you to sign in if the password has expired or if your account has been compromised. On the sign in page, look for Forgot Password and click on it. You will likely have to enter your email address. After this goto your email and look an email from the service provider. It should have a link to reset your password or create a new one. Hope this helps!
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
SOURCE: YM error 81003005/log-in ID, password invalid
I observed that this yahoo messenger comes with the network's (where you are connected at) firewall restrictions. There has got to be in between with your YM and the firewall. This problem is common when you belong to a proxy.
Secondly, if the firewall is the one not bugging you, it might be the DNS servers are causing the troubles. Sometimes, it seems the connection goes well only that DNS problems got in the way. This occurs rarely but if you can catch this problem, headache solve. The second solution discusses this.
Lastly, this has also got to do with the software part, that is the YM itself. As you can read in some of the comments below, other accounts work well and to some do not. If this is the case, then the connection (firewall) itself is not the problem but the software. Yahoo's advise is to update to its recent version of YM. Well, I did this but I was trapped with the same problem. My second solution works well for this kind of problem. Read on.
Solutions
[Solution #1]
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Here's an old version of Yahoo Messenger (8.1.0.419.exe) - [Download]
Hope these helps.
SOURCE: LICENSE ID AND PASSWORD NOT ACCEPTED FOR ACTIVATION
I've had the same problem with other products and had to contact the software provider with my email to verify my purchase and license.
SOURCE: Xbox Live is not accepting my Windows Live ID password
well i have the same problem my network adapter for my xbox the light is green because i have a router but it just wont work
SOURCE: computer will not accept password can not log on
Have you tried in safe mode? If so, then you will need a password reset tool to reset the SAM file in the registry.
There is one located here: http://www.petri.co.il/forgot_administrator_password.htm
But you will need to learn how to use it as these are tricky and can cause MAJOR damage to your OS.
SOURCE: i don't remember setting up
Default admin username:admin
Default admin password:motorola
Default SSID (wireless username):Motorola
you can also check out this link to have a clear picture of a default settings of your modem:
http://bc.whirlpool.net.au/bc/hardware/?action=h_view&model_id=181
for additional concern kindly leave a comment and i'll get back on you ASAP...
---a score of 4 is highly appreciated-----
---if you think this resolution is helpful kindly click on "YES"----
---you may also leave testimonial-----
---if I help you please help me---
Thank you for choosing fixya
Roger
