Also removed the filter housing and cleaned everything. I get a code 19:FO, flashing with UOI when I run the diagnostic test, but can't find the meaning of those codes. thanks so much
SOURCE: Random electrical problems, sometimes it works beautifully, sometimes not!
F11 =
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
SOURCE: lg dryer tromm dlg5988w flashes filter code will
Check your filter, your vent and clean them well. Shut down the power and let it reset itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
SOURCE: The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
Close the washer and press the START/PAUSE/Cancel
button to remove error displayed and restart the cycle. If it doesn't work, it means that
the valve at the water entry needs to be replaced..
Hope this helps..
