20 Most Recent
LG DLG5988 Gas Dryer Questions & Answers
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
LG DLG5988W Gas Dryer (NO HEAT)
I'm pretty sure that the cooling light is always on and blinks when it is cooling. I look at my brother's and he has the EQ bar and it acts the same.
Dismantling my dryer
Great detailed directions on disassembling the LG Dryers on You-Tube. Much more helpful and accurate than a narrative from me.
Also, you can run the dryer with it partially disassembled to observe what is happening and to troubleshoot the problem.
How to reboot the computer on my dryer
if it seems that the contols are locked could be your child lock is on
to unlock it do the followingTo enable the Child Lock feature: Press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. A single DEEP Tone is heard, and CL is displayed. To unlock, press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. The indicator light turns off
i hope this helps
Does not heat
If it is electric it is probably the heating element. If it is gas it is most likely the gas selenoids.
The dryer does not heat.
It is possible the over temp snap switch could be bad, but also they were in the right direction with an air flow problem too. The duct needs not to be restricted, and you must verify the blower fan is in good condition, turning, and also free of debris.
