SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
SOURCE: Sceptre X32GV-Komodo
See troubleshooting (p.96-99) of user manual
but Unfortunately i think this problem is for Sceptre ...
For technical help, contact our Sceptre Technical Support Group via email or
phone. Please have your Sceptre p/n number, serial number, and date of
purchase available before you call.
Tech Support E-mail : [email protected]
Customer Service Email : [email protected]
TEL : 1800-788-2878
Operation Hours : Mon - Fri at 8:30 AM – 5:30 PM Pacific Standard Time
SOURCE: Hitachi Big Screen TV 46 inch Problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
SOURCE: Samsung 940BX LCD monitor 9
The IPboard part no. BN44-0012A is bad. We had to replace 5 monitors with the same problem. If under warranty call 1-800-Samsung for repair or exchange.
Korhan Balimtas
SOURCE: black screen
There is a post by Stivo on this board that has helped many fix this type of problem. There are two capacitors on the power supply board that go bad and if replaced can fix this problem . The parts can be purchased at your local Radio Shack for about five dollars or less. I just did it today and it worked!!!
