20 Most Recent Hitachi C21-F200 21" TV Questions & Answers
you can set the laguage on the remote control.go to menu and try to find the language set up menu...
Hitachi C21-F200... | Answered on Jan 20, 2015
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Hitachi C21-F200... | Answered on Jan 01, 2014
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Hitachi C21-F200... | Answered on Jan 02, 2011
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Hitachi C21-F200... | Answered on Jan 01, 2011
There are a lot of local service centers in the city, I don't know where you can find it exactly, why don't you check the yellow pages? The remote problem is not one that would cost a lot and you don't need to go the authorised Hitachi Service.
Hitachi C21-F200... | Answered on Nov 17, 2008
Hello Michael, I sent you the link of the user manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, te envio el link del manual de usuario
Espero puedas solucionar el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/47/4667/466619-hitachi/22ld5550u_users_manual.pdf?57aa459728c869ba6c471ef6617d380f&take=binary
Hitachi... | Answered 3 days ago
Your Hitachi remote controls are not functionally interchangeable. Win some, lose some.
Hitachi... | Answered on May 18, 2019
Hello Grant, I am sending you the link to download the user manual of your Hitachi TV and check out the procedure of what you need
I hope that my suggestion serves you and you can resolve your concern
Hola Grant, te estoy enviando el link para que descargues el manual de usuario de tu TV Hitachi y consultes ah? el procedimiento de lo que necesitas
Espero que te sirva mi sugerencia y puedas resolver tu inquietud
https://www.libble.eu/hitachi-l46vf04u/online-manual-649167
Hitachi... | Answered on May 17, 2019
Turn it off and then on again.
Please let it close for some time and then again turn it on.
Hitachi... | Answered on May 12, 2019
Hello Taimoor, it would be good if you indicate the Hitachi model that you have, to give you an accurate answer
You can try entering Menu, go down to System, enter with OK key, and go to Language Menu, press OK and the different languages will be displayed, choose the one you want, press OK and ready
I sent you the link To download the user manual of a Smart Hitachi 55 ", on page EN18, the way to do it appears
I hope you find my comment useful and you can solve your concern
Hola Taimoor, seria bueno que indiques el modelo de Hitachi que tienes, para darte una respuesta certera
Puedes probar entrando en Men?, bajar hasta Sistema, ingresar con tecla OK, e ir hasta Men? de Idiomas, pulsar OK y se desplegaran los distintos idiomas, eliges el que deseas, oprimes OK y listo
Te env?o el link Para que descargues el manual de usuario de un Smart Hitachi 55"
Espero te resulte ?til mi comentario y puedas resolver tu inquietud
http://www.hitachi-america.us/products/consumer/tv/docs/tvs/mx/alpha-smart-tv/M49N6_M55N6_Owners%20Guide.pdf
Hitachi... | Answered on May 06, 2019
Try this link for your manual.
https://www.manualslib.com/
Hitachi... | Answered on Apr 23, 2019
Hitachi C21-F200 21" TV Logo
8 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
am attaching digital
  • Televison & Video
