20 Most Recent
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Questions & Answers
Transporting
No the cabinet is none removable on this model.
No power to hitachi 51f510
Ok first of all unless you know how to use a multi meter give it up and take it to a shop
otherwise start testing voltages with a mutli mete
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Red screen
go to the ez adjust menu and reset the factory values do not select the ad9883 u may damage the tv u will need a tech
