I like to use .psd files. But sometimes, more exactly, yesterday I couldn't open my important .psd graphic file.
SOURCE: can't save my psd file
search and destroy / modify the file 'editing.xml' in your 'application data' directory.
it will be in your %temp%\..\..\Application Data\Adobe\Workflow
(if ur operating is win 2000 / xp)
have a nice day
bye
SOURCE: if i have wordpress theme psd file i mean
hi,
listen your psd file is only an image file. just uploading that wont make ur theme available in ur wordpress. you have to design your theme with HTML and CSS just like the one u see on the psd file. that is with reference u have to design it and then upload the html file , images and css to make ur theme available.
Testimonial: "thank you so much"
SOURCE: Adobe Photoshop CS3 program will not open PSD files on CD
For working out given trouble you may use psd repair. Tool is able to recover corrupted and deleted psd files after power failures, viruses, hacker attacks. It starts under low system requirements.
SOURCE: Photoshop15 .psd file crashes on startup
I suggest the following which worked for me.
Open the Photoshop program folder and open the Plugins folder. Move all the plugins to a separate empty folder on your desktop. Be sure there are no files in the Plugins folder
Next restart Photoshop 2015. If it opens correctly replace the plugins, one by one, into the Photoshop Plugins folder and restart Photoshop 2015 after each individual replacement. When Photoshop 2015 stops starting correctly you have found the offending plugin(s).
After doing the above I found two plugins that caused my problem. Downloading updates for the offending programs that were created to solve Photoshop 2015 plugin problems and installing them solved the issues for me so I can use those plugins again.
Also I found this program Photoshop Fix Toolbox https://www.fixtoolbox.com/photoshopfix.html
