20 Most Recent Adobe Photoshop 7.0 for PC Questions & Answers
my serial number Adobe Photoshop CS Serial
1045-0698-5460-2637-3409-8631 i need autotization code
Adobe Photoshop... | Answered on Sep 12, 2019
hi this is ajay i have a chinese mobile which runs .avi ther is a solution for this download xlisoft 3gp converter then make the settings as shown make the video format mjpeg then frame rate as 8 and video size 160*128 audio codec pcm_s16le and sample rate 8000 and channel mono(1) then convert it will work perfectly. happy converting
Adobe Photoshop... | Answered on Jul 30, 2019
Please find the details below...........
1045-1209-6738-4668-7696-2783
1045-1208-8261-8319-6942-3707
1045-1934-9918-5483-5057-6230
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Adobe Photoshop... | Answered on Jul 05, 2019
You have to use the burning software like nero to create a DVD from a .wmv file.Start your nero software and select which file you want to burn .select Dvd video .now it will ask you to add the video files.so click on Add ,when adding the files is over click on Next.Now it will ask for burning speed select the lowest speed ,it will burn the cd with good quality........now finally click on Burn .and nero will start burning the cd when 100% is over click on finish ..that's it
Now one problem can occur while adding the files,that nero may not add the .wmv files.so to resolve this problem use video converter to convert the .wmv files to any other file that nero support like mpg..and when done follow the procedure given above.
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
The probable causes could be due to Data for CD not transfering during the installation.
Here some options you can try,
1. Infected PCs. (Scan PC for virus & malwares)
2. Dirty or bad CD installer. (Use another CD)
3. HDD space for the installation.(Remove some of your data for space allocations)
4. Security Programs running in the background. (Disabled any Security Programs before installations)
5. Too many junk files in your "temp" folder. (Use the CCleaner to clean up your PC and reinstall the program.)
Hope it helps & good luck.
Adobe Photoshop... | Answered on May 26, 2019
http://torrents.thepiratebay.org/3967056/Adobe_Photoshop__CS3__Extended___Crack.3967056.TPB.torrent
this is a torrent file.
u need bittorrent or utorrent client(these are freeware) to download these files. Ths Torrent includes CS3 Setup + crack file. You can download both or only the crack.
if u wanna giv a try to Portable CS2, or 3 here are the Links:
CS 3 xtended: http://kewlshare.com/dl/28feae4e76ab/Adobe_20Photoshop_20CS2_209.0.2.rar.html
projectw.org
CS2:
http://rapidshare.com/files/165130635/portable_Adobe_Photoshop_9.0_CS2_Portable_Espa_ol.rar
http://rapidshare.com/files/32692207/Photoshop_CS2_Portable.rar
http://www532.megaupload.com/files/32c5ecae75826dd4f0964edb0d6119cf/Portable.Adobe.Photoshop.CS2.v9.02.zip
Adobe Photoshop... | Answered on Apr 25, 2019
You can download it at full price on http://www.photoshop.com/
If you choose to not want to pay, you can download it illegally from links on Youtube.com or ThePirateBay.com PLEASE, be careful.
Good luck :3
Adobe Photoshop... | Answered on Apr 06, 2019
I had the same problem. I run windows 7 professional 32 bit O/s and after many hours of the console not being recognised I came across a link at the fisher Price website. I downloaded the software as it describes and bingo...up and running.
hope this helps
http://service.mattel.com/us/faq_results.asp?contentidlist=62056&faq_id=62056
Adobe Photoshop... | Answered on Feb 03, 2019
First uninstall http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe
Then it finally worked for me
Adobe Photoshop... | Answered on Jan 25, 2019
noavatar_s.gif j_whitmill Nice SPAM for your stupid pay site loser! Kill his account!
this is serial number for adode photoshop cs and image ready
1045-1756-0999-0999-3438-3575
Adobe Photoshop... | Answered on Jan 21, 2019
hi,
it is located in program files/adobe/
cheers
mich
Adobe Photoshop... | Answered on Dec 07, 2018
The Photoshop scratch disk is your hard drive. Photoshop uses your hard drive as temporary "swap" space, or virtual memory, when your system does not have enough RAM to perform an operation. If you only have one hard drive or partition in your computer, then the scratch disk will be the drive where your operating system is installed (the C drive on a Windows system).
You can change the scratch disk location and add multiple scratch disks from Photoshop Preferences. Many power users like to create a dedicated hard drive partition for the Photoshop scratch disk. Although Photoshop will function with a single scratch disk on the system partition, you can improve performance by setting the scratch disk to be the fastest drive in your system. Other useful guidelines for setting scratch disks are to avoid using the same drive where your operating system is installed, avoid using a drive where the files you edit are stored, and don't use network or removable drives for a scratch disk.
If Photoshop is shut down improperly or crashes in the middle of an editing session, this can leave fairly large temporary files behind on your scratch disk. Photoshop's temp files are typically named ~PST####.tmp on Windows and Temp#### on Macintosh, where #### is a series of numbers. These are safe to delete.
If you're getting an error message that the scratch disk is full, it means you need to clear some space on whatever drive is defined as the scratch disk in Photoshop Preferences, or add additional drives for Photoshop to use as scratch space.
Adobe Photoshop... | Answered on Nov 12, 2018
The basic photoshop album starter edition is free : Adobe - Adobe Photoshop
Adobe Photoshop CS3 is not free, you can only download a tral version: Download Adobe PhotoShop CS3 Free Trial
Adobe - Downloads
Adobe Photoshop... | Answered on Oct 31, 2018
Try calling the company and tell them you bought the program and the serial no. doesn't work. If that doesn't work do a your favorite search engine serial for photoshop elements 7. Warning, do this can cause harm to your computer, with adware, mailware.
Adobe Photoshop... | Answered on Oct 28, 2018
i have change my phone password at night , my phone baterry get low and the phone get off.when i on the phone ,i forgot the password.
Adobe Photoshop... | Answered on Oct 23, 2018
Errors such as this could happen when an older version or BETA (testing) version of Photoshop CS has already been installed on the computer, or when your registration information file does not get written properly or is corrupted. When there exists multiple copies of Photoshop in the Applications folder, your system and Photoshop may get confused and encounter conflict with which files it should use to verify personalization. The same case could happen if there is a BETA version of Photoshop currently or previously installed on your computer. This conflict can lead to personalization errors when launching the application.
The Photoshop CS installer personalizes the Photoshop CS application within the Applications folder alphabetically. If multiple instances of the Photoshop CS folder are present, only the first one alphabetically will be personalized. New installations of Photoshop CS (which folder falls alphabetically after the first installation) will not be personalized.
A damaged or incorrectly written personalization file (userreg or ps.sif) can also cause Photoshop to return a personalization error when you start it. Some troubleshooting steps which I recommend are as follows:
Solution 1: Uninstall and then re-install most recent version of Photoshop.
If Photoshop's serial number is not displayed on the bottom of Photoshop CS's sg Photoshop, you may have another version of Photoshop CS on the computer. Uninstall the copy of Photoshop and reinstall it. It is especially important to remove any beta copies of Photoshop you may have.
How to remove and uninstall Photoshop: 1. Move any personal files from the Adobe Photoshop CS folder(s) on the hard disk to another location. 2. Uninstall Photoshop from the control panel 2. Delete all Adobe Photoshop CS folder(s) in the Applications folder if there are any. 3. Drag the Users/[user name]/Library/Preferences/Adobe Photoshop CS Settings folder to the Trash. 4. Insert the Photoshop CD-ROM, double-click the installer file in the Photoshop folder on the CD-ROM, and then follow the on-screen instructions to complete the installation.
Solution 2: If the reinstallation did not work, download the Adobe Creative Suite Cleaner Tool at http://www.adobe.com/support/contact/cscleanertool.html
Just follow the instructions on the same page mentioned. This will help you clean out all the files of Photoshop that was installed to your system, as well as the registries that may also cause conflicts.
Solution 3: Use the ImageReady personalization file.
If Photoshop's serial number is displayed on the splash screen, or you performed the solutions referred to above, the cause of the errors is a personalization file that is not written correctly or is damaged. If you can successfully open ImageReady, you can use ImageReady's personalization file for Photoshop.
To Use the ImageReady personalization file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder. 3. Locate the USERREG file in the Resources folder, and drag it to the desktop. Keep the Resources folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder. 6. Locate the USERREG file in the ImageReady Resources folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Restart ImageReady to make sure that the USERREG file was copied, not moved, to the Photoshop Package's Contents/Resource folder.
Solution 4: Replace the Photoshop .sif file.
If Photoshop does not open without error, also replace the .sif file: 1. Ctrl+click the Adobe Photoshop CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 2. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 3. Locate the PS.SIF file in the ASN folder, and drag it to the desktop. Keep the ASN folder open. 4. Ctrl+click the Adobe ImageReady CS application file in Applications/Adobe Photoshop CS and choose Show Package Contents. 5. Open the Contents folder, and then open the Resources folder and the ASN folder in the Resources folder. 6. Locate the PS.SIF file in the ASN folder, and copy it to the Photoshop Package's Contents/Resource folder. 7. Close all open folders, and restart Photoshop. Also restart ImageReady to make sure the PS.SIF file was copied, not moved to the Photoshop Package's Contents/Resource folder. 8. In setup editor, under components, expand the Typelibrary.tlb component. Expand advertising and remove all entries under it. (should be only one.) Compile and install.
Adobe Photoshop... | Answered on Jun 13, 2018
There are multiple was to accomplish photo editing.
Old school, by using editing software on your system. This ranges from very technically complicated, but very powerful, [and very expensive] editing software like Photoshop CS4, to more more moderately prices [and more basic user friendly] software packages, to free software like Picasa from Google.
All have benefits and drawbacks. I am sorry but to give even a primer on the use of a package like Photoshop would take pages. There is much information online. Many photo quality printers come with software utilities to edit photos. For instance HP has its "Photosmart Essentials" that comes with it Photosmart printers.
The latest way to do minor editing of photos is online, in your browser, with services like "Picnik" [ http://www.picnik.com/ ]. It lets you upload, manipulate photos for free [though there is a paid "premium" service as well].
The best way is to experiment. If you keep a copy of your original files safe in a separate place from the copy you are working on you can use any of these solutions to make changes and learn by trial and error [the way most of us did it] and in a little while you will be making photos that will delight you, your family and friends.
Hope that helps some to get you started.
Adobe Photoshop... | Answered on Jun 08, 2018
1,618 questions posted
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Alun Cox
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adobe Computers & Internet
Most Popular Question
download photoshop 7 0
  • Computers & Internet
