Washing Machines Logo
V
Vlad Borman Posted on Jul 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot find online Kenmore washer 110.47767292 info. Looking for part number for lid switch
  • Vlad Borman
    Vlad Borman Jul 26, 2017
    Part number is from the device itself and is correct. A bit old washer, bought in 1997
cwradio73
Level 3:
  • Master 1,162 Answers
  • Posted on Jul 26, 2017
cwradio73
Master
Level 3:
Answers
1162
Questions
0
Helped
363899
Points
3460
You have written part number down wrong . sometimes 1 an l or i look similar. 0 can look like o. its easier to search by model number than parts at sears
5 Related Answers
Anonymous
  • 550 Answers
  • Posted on Aug 29, 2008
SOURCE: Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Anonymous
  • 750 Answers
  • Posted on Oct 08, 2008
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Anonymous
  • 1122 Answers
  • Posted on Oct 26, 2008
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Anonymous
  • 87 Answers
  • Posted on Jan 23, 2009
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Anonymous
  • 101 Answers
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
Kenmore 80 Series Washing Machine will not drain/spin. Model #110.28882790 Serial #CH0249328 60 Hz Heavy Duty Super Capacity Plus Quiet Pak I put a load of wash in before going to work and when I came home...
The usual problem when that type washer does not drain/spin is a broken lid switch. The lid switch is mid center side of the rim of the lid opening when looking at the washer from the front.ina lot of case by looking in that area ya can see where its broken and hanging down,if ya can not see it phyisically broken ya can open the lid and close it slowly and listen for a click when the lid is mostly closed,do this a couple times,if ya do no thear a click when lid is almost closed the switch will be tha problem
This youtube video will show ya how to replace the lid switch. http://www.youtube.com/watch?v=MFsvLiuTniU
The part number for that lid switch is 3949247 it could be picked up at your local appliance parts store or online at;
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Washing machine model # 20707990 . fills up with water but does not drain. What could be the problem?
THe leading cause of the Kenmore washer not draining is a broken lid switch. http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
The part number for the lid switch on your model is 3949238 it could be purchased from your local appliance parts store or online at;
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Washer model#11092282100 won't drain or spin
The leading cause of the water not draining and the washer not spinning is going to a broken lid switch. This tip i wrote about the lid switch will explain how to check if its broken and also how to replace it. http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
The part number for the lid switch on your model# is 285671 it could be purchased at your local appliance parts store or online at;
apdepot.com
partselect.com
repairclinic.com
apwagner.com
GENE
2helpful
Kenmore washer 110.92587210 lid switch dropped away from under the lip
The lid switch asm. is broken and would need to be replaced.This youtube video will show you how to replace that lid switch. http://www.youtube.com/watch?v=MFsvLiuTniU
The part number for the lid switch for your model number is 285671 it could be purchased at your local appliance parts store would have one or it could be ordered online at;
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
The agitator won't work, and the button under the lid fell off. What can we do to fix it, or would it cost too much to fix it?
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
IF THIS IS A BASIC KENMORE / SEARS TOP LOAD, DIRECT DRIVE WASHER THE PROBLEM IS LIKELY A LID SWITCH. (EASY AND INEXPENSIVE TO FIX)
I'D NEED TO KNOW THE BRAND AND MODEL NUMBER TO BETTER SUGGEST A SOLUTION.
3helpful
2answers
Where do I Find the model number on my Kenmore Elite Top load washer?
The model number on Kenmore top loaders is usually printed on a nameplate along the wash tub rim opening under the washer lid. The model number has 8 digits with a prefix of "110". If you cannot locate it, please let me know. I hope this helps you.
2answers
My Kenmore washer 26 26962 MO 110 26962503 will start the cycle..
It sounds like it is your water level control. Here is a link to the Kenmore site which has your manual use these numbers ( Kenmore washer 26 26962 ) for your model unless asked for more Kenmore Manuals
Kenmore Automatic Washer
This is a very common description of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first, then check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. If you do not wish to order online, take the part number provided by Sears and go to your nearest appliance parts retailer. This is a common part that most carry. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid.
Need a diagram for a lid switch
Hello jafarrell
Huuum
2helpful
Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Alexander
vince
