Still your batteries are bad. Had this problem before. If the batteries are more than 1 to 2 years old they need to be replaced. The charger only tells you it can't charge anymore, because the battery is sulfated. The meter on the chair is telling you the batteries are not strong enough to run the chair.
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
SOURCE: Just bought sed Jazzy Select for my wife. Chair
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
SOURCE: I have a jazzy select
Hi standbydrive,
I see that you are having issues with you Power wheelchair Jazzy select6.
You mentioned that it has new batteries but it does not Turn ON. you tried charging your mentioned but the green light does not come on at all.
If I may ask have you check the connections on the Wheelchair if they are all connected properly, possible that it may have gone lose one of the reasons why when you try conencting the charges it does not give the green light.
there are two power connectors and if one of them is lose or is incorrectly connected it may not charge properly or may not charge at all.
for further details I have placed a link for you to see more details on the issue and for your furture reference regarding your Jazzy 6 power wheelchair, see link below.
Manual and troubleshooting guide
I hope that this will be of much help regarding your concern.
Thank you for choosing Fixya,
mvincentc
SOURCE: My Pride Jazzy Jet 2
Are you comfortable working on the electronic cable / connector?
Check the temperature charger's by hand. It should be warm to the touch when power on.
Since you has the unit plug in for days,it should be warm to the touch.
You will need to has a volt meter to check the voltage output on PIN 1 and 2.
Remove the power cord from the outlet.
Inspect the 3 small pins on the XLR (ROUND connector) to the scooter.
Make sure the 3 pins are not damage.
Open the metal 3 pins connector by sliding it back on the cord.
Check for loose connection on the solder tabs.
There should be total of 3 solid solder connections these tabs.
Close up the connector.
Check the connect on the scooter end.
The 3 pins must be clean and able to make the connection.
Please post more information and result on reply.
