SOURCE: my Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
SOURCE: needle thread will not pick up bobbin thread
I finally had to take it in for repair at Sears
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
