"to copy and paste a paragraph" - I just used my c7 to copy the prior phrase from you the text in your question and to paste it into this "add your solution" answer box. Here's how I did it...... 1-I placed the cursor in front of the word "to", and while holding the touchpad down with my left finger, swiped the cursor through the phrase to the end of the word "paragraph" (thereby highlighting the desired phrase), then lifted both hands. 2- With the cursor over the end of the highlighted phrase, I used my left finger to hold down the "alt" key to the left of the touchpad the clicked the touchpad causing the drop-down copy menu to appear, then lifted both hands. 3-I then used the touchpad to move the cursor over the word "copy" in the drop-down menu and clicked the touchpad.
4-Then I placed the cursor in this "answer" text-box clicked once once. Next I held down the "alt" key to the left of the touchpad and clicked the touchpad to cause the "paste" drop-down menu to appear and raised both hands. Finally I moved the cursor over the word "paste" in the drop-down menu and clicked the touchpad, thereby successfully copying and pasting the phrase from your question. PS - an alternative to holding the left alt key and clicking to get the drop-down menu is to place two fingers on the touchpad (about a half inch apart) and click with both fingers simultaneously. The latter method only works about 75% of the time for me, so I recommend using the alt key.
Make sure your palm or more than one finger is not covering the touchpad. Laptops manufactured before 2013 did not understand "Multi-touch" on touchpads. Use only one finger on the touchpad and problem should be solved. If it doesnt, the touchpad is damaged. Buy a mouse.
Boot into the ThinkVantage Recovery partition during startup by pressing the blue ThinkVantage button on the keyboard. See whether the TrackPoint and trackpad work consistently in there. If you don't have the recovery partition, test the problem in this: http://support.lenovo.com/en_US/downloads/detail.page?LegacyDocID=MIGR-6291 Use ThinkVantage System Update to download all the latest drivers, firmware, and updates.
it depends what brand product you are using. for most touchpads you just drag two fingers next to eachother on the touchpad and it will scroll up and down. for some others you just drag one finger along the edge of the touchpad
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad before moving it to the scroll zone.
Go to control panel -> Mouse -> "Device Settings" tab (has the synaptics logo to the left of it) -> Select your touchpad -> "Settings" -> expand "Scrolling" -> "One-finger Scrolling" -> uncheck "Enable Vertical Scrolling" and also uncheck "Enable horizontal scrolling"
If you don't have "Device settings" in the mouse setting window, then you need to install the drivers from http://www.synaptics.com/support/drivers
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
dont go all the way to the edge, most pads have a scrolling feature built in mine is on the far right of both my laptops and if i hit it the page will scroll up and down as i move my finger
