Sewing Machines Logo
Efrain Rodriguez Posted on Mar 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my machine break the thread a lot? A juki cp 130
R.A. Ellis
Level 3:
  • Juki Master 12,731 Answers
  • Posted on Mar 13, 2017
R.A. Ellis
Juki Master
Level 3:
Answers
12731
Questions
Helped
2619462
Points
59176
Watch your thread while sewing slowly. You may be able to see where the problem originates. It may just be a matter of the thread popping out of a thread guide or looping around something it shouldn't.
Avoid old or bargain bin variety thread. Invest in fresh, good quality thread.
Try installing a brand new needle.
When threading the upper thread, ALWAYS RAISE the presser foot. Remove all the thread from the machine and rethread from the beginning. Confirm the thread path is correct and that the bobbin is loaded and threaded correctly. Set the tension to the midway point to start and then tweak it for your particular machine.
Sewing Machine Problem 1 Thread Breakage
Why Does My Thread Keep Breaking While Sew
Sewing Machine Thread Keeps Breaking
Juki MF-890 Industrial Coverstitch Sewing Machine. How to thread the Judi MF-890 please?
Question edited for a lot more clarity - 'Judi' lol.
Question moved from Televisions category.
Manuals
https://www.google.com/search?q=juki+mf-890+manual
Threading
Juki MF-890 - Threading Diagram
Superior Sewing Machine & Supply LLC https://www.supsew.com > wpfb-file > juki-mf-890-th...
Juki MF-890 - Threading Diagram ; File Size, 0.5 MiB ; Date, September 20, 2016 ; Downloads, 721 ...
1helpful
Juki CP-130 E24 Error code
The E24 error code for the Juki CP-130 sewing machine usually indicates a problem with the thread take-up lever. Some common causes of this error include a thread take-up lever that is not properly installed or adjusted, a bent or damaged thread take-up lever, or a thread take-up lever that is blocked by lint or debris. To resolve the issue, check the thread take-up lever and clean it if necessary, and make sure that it is properly installed and adjusted. If the issue persists, you may need to have the sewing machine serviced by a professional.
Hello I have a problem with my sewing machine machine. Juki sc-1 type GB. When I turn on on display first is error 25 then 26 and the number 210259. Anyone know how I can fix? Thanks
Page 42 of the Service Manual shows both Errors 25 and 26. Talking of Errors, I fixed all the errors in the question to British English :>)
ENGINEER'S MANUAL - Superior Sewing Machine & Supply ...
www.supsew.com > download > Juki > Juki SC1
PDF mJUKI. 3C-1. SC-2. CP-30 'CP-ISO. CP-230'CP-330. ENGINEER'S MANUAL. 4-. 1.. caoo <r £• ... 24. 14) Number of revolutions at low speed. 25. 15) Number of revolutions for thread trimming. 25 ... 26) Needlebar up/down position retaining function. 32 ... EXPLANATION OF ERRORS AND CORRECTIVEMEASURES. 38. 6.
How to thread a juki cp 180
I am surprised that I couldn't find threading directions in the manuals that I found. It appears to me that you can thread it the same way that you would thread a Juki DDL 555 or DDL 8700. Manuals on Line have several manuals but I couldn't find threading directions in them. Weird. Most sewing machines thread similarly whether they are home or industrial machines. Once in a while there will be an odd one. Sergers, etc are another matter but sewing machines are generally alike in their threading.
I want to know how old is a Juki cp 130 with serial no. DDL8500-7, and what the value would be. I am thinking of buyiny iy.
I bought one 2 years ago used from a juki dealer in NYC for 425.00 used. I'm selling mine on craigslist for 300.00 where the dealer said he'd buy for 200.00 and sell for double
they are 6 years old but were one of the first ones to cut thread when you back kick.
3helpful
3answers
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 • Juki TL-98Q
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
