SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
SOURCE: I need help with electric wheel chair batteries for a Pronto M91
after fully charging the batteries I plug in the control and it flashes once and then it is dead and the batteries are in recharge mood?
SOURCE: My wheel chair wont work
Hi,im disabled also.The sequence of the bleeps could be a sign to tell the manufacturer as to what part on it has gone wrong.its a basic as that,but you will not be given that info if you contacted the manufacturer,why?cos they dont give out technical info out to end users i.e. you as in the person who has bought the product,plus are you still under warranty.& give age concern a call they may have info on helping people in this situation.or look in directory for nearest repairer for your product,and the technical boys or girls there will be able to get hold of manufacturer and be given the explanation of a problem being they are qualifed.i really hope your back on your travels soon colin.
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: 2001 rascal electric wheelchair booklet
http://www.scootaround.com/resources/manuals.htm
If you scroll down to Electric Mobility you will find the links to 14 different Rascal Electric chairs as they are listed by product number im afraid i couldnt pin it down any more then that
